In my 66 fj40 its has a new 1978 2F
with a new water pump/oil cooler /fan clutch & 7 blade fan. I also instaled a new for 4 core Radiator, and recently aquired a later 2f fan shroud 1979 fj40 (Thanks miker) that bolted up to radiator & support frame great ! put it up to fan and the fan blades contact fan shroud
on the top.
I then shimmed up 5/8" the fan clears fan shroud fine......In my mind the center of the 1F and 2F should be the same ?
My question are : is the 2F engine 5/8" higher than the Old 1F ? did I use the wrong moter mounts 2F type (NEW) ?
Is the water pump/oil cooler/fan clutch different hight wise 5/8" ?
The fix is add a 5/8" shim and make permanent ?
Or drill frame support raising radiator and fan shroud up 5/8" ?
or use a later frame support ? (now useing the 1966 frame)
Or has anybody any experance doing this ?
What's the solution ? any
Thanhs JC
on the top. I then shimmed up 5/8" the fan clears fan shroud fine......In my mind the center of the 1F and 2F should be the same ?
Thanhs JC
