I have now read a few threads about noises at start up and there were several posts that people mentioned that the fan clutch could have been a culprit in the noise.
My 177,000 mile 1996 Toyota Landcruiser (No lockers) with all services up to date. I had a baseline performed by the guys at "Urban Landcruisers" in Atlanta.
The noise has started recently (last two months) and has only happened 4 times. The noise sounds more like liquid popping. It reminds me of hydraulic fluid with air bubbles in it popping through valves.
I have used a stethoscope to prod around the engine paying attention to where the chain is because it was mentioned in some threads as causing a start up noise. All I hear is the whirring of an engine. The sound does not seem to transmit through the block.
When I move around the engine bay it stays towards the front of the engine. When I kneel in front of the grill the noise is pretty loud.
When it is starting the engine acts like it is out of balance (rocks a little more than it should) then it runs fine after that. This only happens if the engine has sat for a couple of days without being started otherwise it runs like a top.
The fan is spinning all the time when I look under the hood, even at start up.
It is due for an oil change soon due to time and not miles (Mobil 5w30) and it has a Toyota filter on it that I bought at a Toyota dealership. All the belts are Toyota and repair has used original Toyota parts.
So, am I replacing the fan clutch? or should I dig some more?
