Fan Clutch issues
Brisbane
Does everyone’s fan run all the time? Mine seems to run even when the rig is cold. I’ve serviced the clutch with fresh oil 36ml, cleaned the heat coil of all the debris but still it runs all the time, is this normal?
1FZFE
check the factory timing on the fan clutch. There is a write on on DYI how to tune factory clutch. Do a search.
Mine is set to open @ 190
It should always spin, normal. The question is; how much drag does it have, with the motor off, can you turn the fan?
With the engine cold: I can spin the fan but it stops promptly.
With the engine at running temperature: I can spin the fan but there’s less resistance and also stops promptly
Sounds normal, now drive it, watching the temp gauge, how does it perform?
It’s driving fine, temp gauge doesn’t go above halfway.
Will the fan speed increase if it hits a higher temp? Otherwise it seems pointless having a temp controlled clutch fan that’s always spinning?
