Fan belt replacement
OK, I'm an idiot...
I've got an F engine my 74FJ40, with what looks like an updated radiator and fan/shroud. The fan is continuously driven off the crankshaft.
How does one replace the belt and adjust the tension on the belt? There are no other tensioner pulleys, just a single belt around the crankshaft pulley and the fan pulley. Does the entire fan/radiator assembly need to be removed in order to change belts and adjust tension? Haynes doesn't even make mention of "Fan" or "Belts" in the index adn the pics only show what I already observe there on my truck...no help on actually servicing it.
thanks all,
John
Belt.....What belt????
I have the same rig (74 with the F engine).
I am just running the one belt. Crank/fan/alt.
It is one thick heavy duty belt and doesn't ever slip so why add a second belt?
I do keep an extra with me as a habit though......
no the fan or shroud does not need to come out, just take the old belt off and around the fan(new one same deal). belt will adjust with the alternator(or snog pump, just depends), if there is no screw adjuster then you just take a pry bar(make sure its against something that wont brake) and pull back againt the alt till its the proper tension, then snug the bolt down.
re read you post, you only have ONE belt and it only goes around the fan and crank? how about the alt or snog pump? If the belt ONLY goes around the fan and crank then thats not right........
HMMM...you run yours "serpentine-style" around the 3 pulleys and tension using the adjustable bracket on the alt? With such wide angles around each pulley, I was concerned that there wouldn't be enough surface contact between the belt and pulley on all 3 to be sure they's all be engaged unless the tension was very, very high (not good for longevity.)
I assume you have a series of spacers installed because IIRC, my pulleys aren't all aligned.
thanks,
john
Senior Pimp...
I have 2 belts...#1 is around the crank and alt (i loosened the alt tension adjuster and slipped that belt off no problem).
#2 is only around the fan pulley and another crank pulley, that one inboard of the alt belt pulley. #2 is tensioned, and there appears no way I can easily ascertain to loosen it enough to get off the pulley and fan. Even if I could slip it off the pulley, its diameter is so small I am not sure I could slip it around the fan.
does that help describe the problem?
yep, someone removed the smog pump which is where the belt would have been adjusted at, the PO just found a belt that fit the fan(waterpump) to crank..........not the best idea, the water pump is kinda important, I would be worried with no way to adjust it.
which side is your alt? if its low on the driverside you could use a belt from a 65 fj40, which goes alt, crank, fan(waterpump)
but you say your pullies don't line up.......so that won't work prolly
darn PO"s ;)
It runs great, so I'm happy with the simpler no-smog setup (until I move to CA that is!)
Alt is high on the driver's side...I might play with some washers/spacers to see if I can line the pulleys up and run a single belt...
74 won't or shouldn't be an issue in CA for emmsions. I'll try to find the part # for the belt on my 65, it should work if you can line stuff up.
I'd appreciate that.
John
If it did have a smog pump, you can replace it with an idler pulley on an adjustable mount. If they are running "desmogged", some folks just "gut" a smog pump and use it as an idler arrangement. SOR has a (too danged expensive) substiture for the smog pump (as an idler).
http://www.sor.com/sor/cat048c.tam?xax=14220 (down the page a way)
It doesn't fit your '74, but you can get and idea from it.
I, personally, really would consider going back to the original belt path by whatever means.
I agree with the 'Pimp.... it's a scary proposition driving the H2O pump with no tensioner.... With no means of tensioning/loosening, it'll probably be a pain in the arse when you're out there in the gunga trying to change a busted belt in a hurry.
John Sherwood
Charlotte, NC
If its a single belt all around, the Alt would function as the tensioner and I'l be all set...Jujoo, got a pic of the spacers/washer stacks/clamps in your setup that resulted in a lined-up set of pulleys?
The waterpump is tensioned by the alternator today...i think my earlier post about the routing left that out, sorry. Working from memory! The water pump is driven by a belt around the crank, alt and water pump. The other belt is just between a second crank pulley and the fan pulley.
if thats the case and the 2nd belt is just redundent, I wouldn't worry about it, as long as one belt get the crank, waterpump and alt your fine.
just to beat the dead horse though...i'd still like to see the pics of the pulleys lined up, because I still haven't solved my problem of replacing the crank/fan belt which has NO tensioner and I still can't figure out how to get it off!
One belt is a cinch!!!!!
I'll take a pic in the morning and post it as soon as I possibly can!
I was originally concerned about the lack of surface contact as well.
I.E. doesn't wrap the pulleys that much, but as I stated earlier. It hasn't caused
any problems yet for me.......
Sorry that I haven't gotten that pic taken/posted yet. I am at work right now and will be heading to the house at 11. I'll get the pic done and posted as soon as I can!
