- Thread starter
- #41
My drums are where they should be since I fixed the E-brake. They fronts aren't grabbing but after a double pump they do but pull to one side. I had the same thing awhile back and had my regular mechanic look at them. He mentioned the bearing pre-load thing.
The only way (that I can see) that a bearing preload could affect the brakes, is if the wheel (rotor) was allowed to move side to side (by loose bearing preloads) causing the pads to be pushed back off the rotor more than than if the rotor was static. Then when you hit the brakes you will have more pedal travel before the pads actually contact the rotor. I doubt this is the case, but jack up your front end and try to move the wheel up and down, if it moves at all youve got a preload problem.
Are you asking how to set a preload? If so tourqe down the inner 54mm nut until you cant anymore. than back it off just a tad. then use a fish scale or something to see how much force needs to be applied to A WHEEL STUD to rotate. work the nut until you see about 12 ftlbs. then install the lock washer and the outer 54mm until it is tight, then re measure the force needed to rotate. This entire thing must be done with the caliper off.
Does that make sense....dummy.
