Fair warning for all.
Utah
Earlier today, I made a few stupid mistakes that left my hand in a lot of pain.
Preface:
I was wiring a switch for a new set of foglights. The switch I used is an illuminated type, which means it has 3 leads: '+', '-', and a ground for the LED. I had it all figured out :hillbilly:
Working on the truck:
While I was under the dash, however, everything was backwards. Which led me to accidentally switch the two ground leads.:whoops:
Which meant that when I flipped the switch, instead of triggering the relay, it created a short circuit.
Literally within the second, the negative wire heated up and began melting, dripping smoking hot plastic onto my carpet and other wires:eek: I quickly ran around the truck and disconnected the battery....only after burning my hand a few times, trying to disconnect the melting wire.:idea::doh::mad::censor::censor::censor::doh:
Had I not done so, the truck could have went up in flames.
SO, a lesson to all electronic newbies, a reminder for some experienced, and especially to me:
DISCONNECT YOUR BATTERY BEFORE DOING ANY ELECTRICAL WORK!!!
Even if it's a simple switch.
Disclaimer: I realize what I did was stupid and newbish. However, if you really really really feel the need, please feel free to point, laugh, taunt, flame, giggle, or whatever.
yea I've learned that the hard way just like you....
are you going to post up any pictures of your work for us :-p
The learning curve is steep but short, Grasshopper.
I'll do you one better. About 30 years ago I had a short circuit in a parking lot with no tools on hand. Tachometer wires shorted out. Solid core wires as it happens. Only way to cut the power flow was to yank the wires loose by hand. The red hot smoking wires. I still have faint scars on a couple of the fingers that the wires cut and melted their way into. :(
Mark...
I agree disconnecting the battery is a good start but i think a fused power supply to the switch would help too. :cheers:
This was my thought. If a fuse were in-line, it would have just been a bit annoying to change the fuse.
Just imagine if it had been some of the 2/0 that people sometimes lay out unfused.
Now that I think about it, I didn't throw away the melted wire... It doesn't look as gruesome as it did last night though, it just looks like it was stripped.
Agreed. :o I did end up putting a fuse in.
Scary thought. Even I'm not stupid enough to do that! :flipoff2:
well i did almost exactly the same thing, and i had a fuse in line that didn't blow for some reason.
I was wiring up my hella driving lights, had everything run up to the dash to connect the switch in. FOr some stupid reason i went ahead and connected to the battery before walking around to the cab to connect the switch in. While there i needed a little more wire so i pushed some more wire through the firewall. When i did that, i guess the two wires at the switch connected and the wiring all started smoking and glowing red. Smoked started pouring out from under my dash and from my engine bay. Luckily one of the wires melted in half and that was that.
yet another reason why one should put in (I did) a quick disconnect on the battery, besides the dreaded starter fire...
Everything running from the battery should be fused.
I used to have my trailer electrical plug mounted below the rear bumper. One time I went into a hole and the rig came down on that spot and crushed it flat. Immediately I had smoke pouring out of the engine bay. I popped the hood and found a 10AWG wire melting everything it touched. I was able to grab my leatherman and yank the wire out. Needless to say I now fuse all + wires from the battery near the source. I also figured out a way to mount the plug so it isn’t so exposed. I now mount it on the pintle hitch bolt holes. Fuses are goot!
You tried turning off the mis-wired switch first, yes?
If the switch is wired wrong, doesn't matter because 'off' is now 'on' with the wires being crossed. Bottom line is everything should be fused within 12" of the power supply and with a fuse thats not too big.
Key point and one that I forgot during a little OBA project. Scared the crap out of me and could have burned the truck and the house to the ground. My heart rate still rises when I think about it. A 30amp fuse on a 12' run of 14-gauge wire will still let the smoke out before the fuse blows... I promise.
-B-
IMHO everything and I exactly mean *EVERYTHING* must be fused. And fuses must be as close to battery as practical (do not be tempered with “in-line” fuses found in virtually all aftermarket electrical installations – they just pure rubbish). Whenever I start new electric project I do fuse first, thus usually you do not even need to disconnect battery but just take fuse out :idea:. And be realistic with fuse rating – if thing consume 3A then put 5A fuse, not 30A one ;p. And IMHO fuses much better (more stable) then circuit breakers, although obviously single use. But if you check everything twice before first power on then they usually never burn ;p. As per today I have only one problematic wire – 4GA :eek: running between batteries. And although I triple check everything and put it into rugged conduit, I still thinking about put fusible link.
