Failed ca emissions test –
los angeles
Any input would be greatly appreciated.
I have a stocked ’94 with 132K on the odometer and it failed the CA emissions test. Reason for failure, at idle the CO% measured 2.34. It should be zero.
Since the test, the CEL came on. Pulled the code(s) and I get 25 and 26. Possible O2 Sensors. My issue is, I had both O2 Sensors replaced 2 years ago, before my last emission test. At the same time, replace the dist cap, rotor, spark plugs, wires and PVC valve, all with oem parts.
Do you think my O2 sensors have gone bad in two years? They are oem Toyota sensors. What would cause both these codes to be thrown…
Thanks
Doran
I can't pinpoint your problem but this might be a good time to upgrade to a Landtank MAF. When I failed an inspection in CO with my old truck I got a waiver after spending so much money trying to correct the problem (bought a new MAF but still didn't pass).
Never mind.... you have a 94, time to vote with your feet and leave the nanny state.
This is an option but it will be considered a Gross Polluter in California.
My neighbor did this on his 73 Ford and he was still smogging it in 2008.
I'm not getting code 71, so I don't see how this applies.
I
Huh?
What exactly did he do?
My cruiser has failed smog two times in the past. I did have to replace the O2 sensors.......but the last time I just took everything apart (o2 sensors, dist. cap, new plugs, MAF, etc) and cleaned the the crap out of all of them. Surprise, I passed. I have no idea if this could help you pass but its worth a shot. Besides, its free besides your time if you just clean everything really good. You never know, it might help you out! Good luck!:beer:
Landtank's MAF only works with 95-97 vehicles.
You have never heard the phrase vote with your feet, referring to moving to a less oppressive and restrictive state than Kalifornia?
'94 model year is notorious for eating O2 sensors for lunch. How many miles have you put on the truck since you replaced them? My '94 has a snack of O2's every 60K like clockwork. I should just put in a standing order with Dan every 60K.
Landcruisers here in the Republik of Kalifornia are labeled 'gross polluters' period. I have to go to a smog only station because of that designation. I'd failed for bad O2 once also and after lengthy diagnosis a frayed/cut wire down at the harness near the sensor was found. To this day I think the crappy mechanic at a local stealership just cut it to get rid of the code and allow the truck to pass smog. Different dealership found it, repaired it and I haven't had issues other than sensors for lunch since then.
Check with your Toyota Dealer for warranty. I know the mufflers and cats are covered by a lifetime replacement warranty once you buy the first OEM Toyota replacements. If you have an internal headgasket leak and are using coolant, that could wipe out the O2 sensors.
Colorado is stiffening the regulations as well and making it harder for the LC to pass. I had a "sticky" aft O2 sensor. Replaced both O2's and it went through without a problem.
The earlier post with the link was trying to direct you to this site for diagnoistics of the codes. Good luck!
Album: 80 trouble codes-8
Hmm? why do you think the CO% should be zero?
In my Smog Test, it show the CO %:
Maximum to be = 1.10
Average is = 0.10
Your Measurment =0.59 (mine)
Forgot to ask you, have you noticed if your LC is consuming more fuel? does it puffs black smoke when you step on the gas pedal? These are usual signs of bad Ox sensors. While you are down there, I will double check the Oxigen sensor wires for any loose fitments or cut wires.
How's it running? When my 94 was throwing a code 25 and 26 simultaneously, it turned out to be a bad injector. It did have a noticeable missfire though.
No, but I like it...
My cruiser has failed smog two times in the past. I did have to replace the O2 sensors.......but the last time I just took everything apart (o2 sensors, dist. cap, new plugs, MAF, etc) and cleaned the the **** out of all of them. Surprise, I passed. I have no idea if this could help you pass but its worth a shot. Besides, its free besides your time if you just clean everything really good. You never know, it might help you out! Good luck!:beer:
will give it a shot.
Landcruisers here in the Republik of Kalifornia are labeled 'gross polluters' period. I have to go to a smog only station because of that designation. I'd failed for bad O2 once also and after lengthy diagnosis a frayed/cut wire down at the harness near the sensor was found. To this day I think the ****py mechanic at a local stealership just cut it to get rid of the code and allow the truck to pass smog. Different dealership found it, repaired it and I haven't had issues other than sensors for lunch since then.
I've only put about 10K miles since I had them replaced 2 years ago. I'm thinking/hoping it may be a loose wire. Will look into it when I get home.
Average is = 0.10
On the print out the shop gave me, it had the value it needed to be to pass and it was Zero. Maybe new regulations...
Gas milage has dipped a bit, but no black smoke. I definitely need to look for loose wires.
No misfire at all. But I had been thinking about having my injectors cleaned. I'm stumped!
when my 92 failed for the same reason it just needed the valves adjusted.
