Factory Sub Amp - Need wiring info
Philippines
My HDJ81 came with a Factory Sub-amp + Subwoofer. However, PO had replaced the stock stereo system with aftermarket. PO ran separate wires for the front/rear speakers. Since mine was a RHD to LHD conversion, I cannot locate the factory wiring/amp harness anymore on the glove compartment area. Conversion team must have trashed it or disconnected the stereo harneess.
However, last weekend, I had the opportunity to thave the rear panel removed. The stock amp is still there with about 8-9+ wires that go through the amps' input plug- . I would like to connect this amp to the aftermarker stereo by directlying tapping or connecting wires.
Anybody out there got the schematics or wiring diagram for the factory sub-amp? Can you help identifying what the various colored wires are for?
Also, are the two rear speakers near the headliner originally connected to the rear door speakers?
If yes, then I can just probably find these wires, cut them up, and connect to the new rear door speakers. Is it worth? would sound quality be impacted?
If no, where the wires running from/to? Am planning to just replace the original speakers with either tweeters or smaller coaxials. But how do I run the wires from the headliner down to the rear panel?
Thanks,
Podiev
Where would the wires be located
Am wond
Am planning
thanks. sorry I broke the cardinal rule. I should have searched first.
