factory steering stabilizer?
I have the OME (Old Man Emu) one and it's pretty beefy. But from what I understand the factory OEM unit is good also.
NAPA carries one also.
Not sure what you're asking exactly....
Without a pic there's no way to tell if it's factory or not.
Unless it's blown, I wouldn't bother replacing it. The factory one is actually quite good.
It looks 12 years old and when I hit the brakes the steering wheel wants to shake back a forth a lot.
Far more likely to be one of the following:
Loose bolts/nuts
Loose suspension components
Worn wheel bearings
Unbalanced tires
Warped rotor
Sticky caliper
My money would be on the last 3.
I've driven my 80 with 35" tires and a lift without any steering stabilizer at all, and barely noticed.
