factory rear 4 link question
Belmont, NC
Since i'm putting the 80 axles under my Jeep XJ now, i'm thinking about utilizing the 4 link rear setup. My question is, just how strong are the factory arms? What thickness is the tube and how do they hold up on the trail?
Strong. The lower control arms can and will bend if you drag them over a rock, but that's about what it takes. I would strengthen those, and leave the rest. :meh:
if you pulling everything out to do an axle swap, it wouldnt be much more to sleeve the tubes while you got em out. You could add angle iron but with the work youre into might as well go BEEFY :D
the earlier (fj vs fzj) arms are tube vs. solid and greater diameter.....some say it comes w/ some additional strength
and its a 5 link ;)
ok, i may cut and sleve them. rocks is mostly what they will be seeing and they will take a good beating. and yea...5 link...you know what i mean.
ok, on to another similar question.
If i drive the bushings out of the ends, is there a press in johny joint size that will fit? What do you guys do to the arms as far as changing bushings out to joints?
The stock lower arms are wimpy, mine have 1.5x1/4" angle welded to them, now can take rock slams pretty well.:hillbilly:
Nope, the bushings are metric, not aware of any joints that fit. The stock bushings flex pretty well and ride well, if you want joints probably best just to make new stronger arms?
thanks, thats what i needed to know.
by the time you sleeve the links and source metric hardware (if you dont have any) it would be easier to start over
way to use 80 axles on a jeep. arguably stronger than d44s
and its a 5 link ;)
wait... so which one is solid and larger?
Im putting all the std rear 80 series susp coiltops and bars etc, in my 79 series ute with a 105 series ff rear diff for the full rear coil conversion soon, just started cutting bits of chassis atm ill be getting pics etc soon in the 70 section and can get measurments if need mate
Even with the beefier arms, you will bend them.
Spend $50 and armor them. It's cheap insurance.
no, i just hadnt heard that the LCAs were solid. that means my 94 should have solid bars...
I'm just worried about bending them, but if they're solid i feel a little better about it.
I have never seen stock solid lower rear arms, the earlier arms have cast ends and larger diameter, but all of them fold with the rig sitting on them.:hillbilly:
