Factory lockers not engaging?
Central Coast California(Orcutt)
Website
www.facebook.com
Bought My 1st cruiser, But the factory lockers are not engaging. The indicators on the dash just keep flashing. Is this common? Is there a quick fix, or any ideas for me to narrow down the problem? Please help! Newbie
read the FAQs if you haven't already.
Dumb question, but you were attempting to do this with the t-case in "low", right? The lockers won't engage in high unless you add a CDL switch.
You also have to move slightly to get the lockers to "click-in". Same when it comes time to disengage them.
Yuppy,
As a fellow newbie, I was in the same boat. Search the numerous links on here about the locking diffs. Make sure your t-case indicator works, et al...
There is a wealth of info on this site not just on this topic, but just about anything else you can think of!
Yuppy,
Gotmud,
Did you get your center diff and front/rear lockers to start locking finally?
To Mazder,
lots of threads on this and stuff in the FAQs (sticky thread at the top of the 80s section --> https://forum.ih8mud.com/showthread.php?t=84888)
Basic quick checks are to put the 80 in low, ensure your center diff locks, then try to engage the rear and then front lockers. Do this on something other than concrete/asphalt road (like dirt, gravel, etc).
If the lights just keep blinking try some tight turns and/or figure-8s. If the lockers haven't been "exercised" on a fairly regular basis (many us of exercise them at least once a month) then they can take a fair amount coercing to engage.
Do you have a CDL switch and/or Pin 7 mod?
When I bought mine it was the same way.
The culprit of my nonlocking was a copper strip that someone put around the diff fuse to power and after market amp. It spread the pins apart so that the contacts were not in contact. I took it out used a tine screw driver to bend the clamps back down so that they make contact with the fuse correctly.
By the way before I noticed this I took about everything else apart so feel free to bounce questions off me. Its not that hard to troubleshoot if you keep you mind together and have a few tools some spare wire and a 9V battery.
Gotmud,
To Mazder,
Corsair23,
The t-case indicator switch was bad, so I ordered a new one and made a "custom" switch to use over the weekend. Now my front locker won't disengage, but I suspect that has a lot to do with me tearing it apart and not properly aligning everything when it went back together. It makes noise, but doesn't fully unlock the sliding pin. Its not my DD so I will play with later this weekend.
Wiring short or somthing?
Well I finally got the Center diff lock light to turn on and engage. I unplugged the wiring to the transfer case, the one that will give u 1 selection in high. got back in then started shifting the transfer case lever back and forth from hi to lo. Finally the indicator light and abs light came on. I plugged every thing back together to check if it still works. put it in low it still worked. Later hit the closest dirt road I could find and attempted to lock it up 1 at a time. Every thing locked up except for the front. But when i get a little more time and play with it a little more I know I'll get it to work. The thing thats really pissing me off is that every time I attempt to take a trip in the cruiser by myself with out the wife the damn check engine light comes on. I've gone through the whole thing and every thing seems to be ok. What gives? I convinced the wife to let me buy it, it has 190,000 miles on it and i tolt her this is just broke in. If this winds up costing more money she's gonna have my arse, let alone be like I told you so.
