Factory lockers are sticking?
Salt Lake City
I just bought a 94 FZJ80 and I am loving it. As I am getting to know this beautiful vehicle I noticed that when I go to dis-engage the lockers they don't immediately come off. Sometimes I have to roll up to 40 feet before I hear the click and the light goes off on the dash.
Is this normal or a symptom that I might have some issues?
They should come off a little quicker but remember that they do get lazy with lack of use, keep using them and they should improve. Also, once you have switched them off just ease off the throttle and that willl help them disengage.
regards
Dave
regards
Dave
X2 When I bought my LX mine would take several seconds to engage, but after more use its almost immediately now.
Mine are both slow to lock and unlock. At times they don't unlock until i turn the truck a few times back a forth while moving forward. This even after using them a lot.
Is there a place to lube them???
The problem could be that they are not fine splined, they only have 5 big lugs (splines) that have to align for engagement and disengagement. With fine splines (like the Pickup electric lockers or Warn Hubs) the engagement and disengagement is smooth and simple because nothing has to turn very far for spline alignment.
I had the same issue when i bought mine, I found dis-engaging and running in reverse a few feet would quicken the process. Now that I have been using mine more frequently its pretty quick. I don't know could just be me. HTH
The rear is 5 "splines" the front is fine, like the Taco, etc. This has no effect when disengaging.
When disengaging all selectable lockers are under spring tension. If the axle bind pressure is higher than the spring pressure trying to shift the gear, it wont unlock until the bind pressure is reduced. I find that a quick saw back and forth on the steering wheel and/or a blip of throttle usually makes enough wheel slip to disengage them.
Mine seem to lock and unlock MUCH faster(almost immediately) now that I changed out the diff fluid.
