factory locker connector part number??
Vancouver, Canada
Website
www.jjadventuretours.com
Ok, figured out why my rear locker is not working (engaged light flashing); one of the wires on the 2-wire sensor (that senses when the locker is engaged, i presume) has broken off. Unfortunately there is not enough wire left on the connector for me to solder a replacement wire onto it.
So I'm stuck trying for find a part number for this connector. Anyone got any ideas (or an OEM equivalent)? Toyota could only supply a complete wiring harness (forget it!). I need a the connector that attaches to the 2-wire sender on the diff case. Help please!
There is a 5 digit number stamped in raised plastic on the plug. It is very small and the same color as the plug. It will be hard to see. The 5 digit number is the second half of the part number. The first half is 90980-XXXXX
BTW the plug does not come with any pins, it is simply the housing. If you have the housing number you can cross reference them to find the repair splices, the pin and a small section of wire. This should allow you to make the necessary repair. PM with the plug part number and I can look it up for you.
Most dealers won't or don't know how to look this stuff up.
Ok, I am a nerd. If it is the same plug as harness plug for the front sensor it is part number 90980-11250. This is a male housing with female pins. The wire splice part number is 82998-12440.
I would suggest spending $10 on toyota techdoc.com to download the wiring harness repair manual. The pins can be removed from the plug housing but can be hard to figure out if you don't know how to start.
Looked closely at the plug and the only writing on it is "XB-T". I can't actually see the front sensor plug cause it is hidden up on top of the axle, but it *feels* the same, is also a male housing with female pins (and i can't think why they'd use a different plug). Thanks! I was beginning to despair of finding a replacement and was going to just shove connectors onto the pins on the sensor and gunk up the whole deal to keep water out.
The plug is pretty chewed up from me hacking at it trying to expose enough wire to solder a splice to, if i get a new plug I can probably cut open the original to get at the pins inside. Otherwise would appreciate the part numbers for the pins as well. Or does the wire splice include the pins?
You don't need to destroy the plug to remove the pins. I will look at mine tonight.
Look into the plug, you should see a gap above the pins. Way down inside you'll see a small plastic tab. Use a a a slender pointed tool ( I don't know what to call it, I bought a set from Sears, looks like a screw driver with a pointed tip) and push the tab down. This will unlock the pin. While you're holding the tab down pull the pin out from the back. You'll need a little leverage but you don't have to tear it out. It is pretty much the same type locking method used to hold the plugs together.
Ok, got my new plug and splice kit from the Toy dealer, and those part numbers are correct. Thanks! The splice kit only comes with 1 pin so you need to order two of them (doh! waiting for another pin now). Thought i might as well use new pins so it is all fresh and clean.
