Factory Keyless Entry: LX having issues
bpassmore
Site *****
Houston, Texas
Website
brettpassmore.com
Guys,
my LX has recently (as of this weekend) begun to exhibit funkiness with regard to the key-less entry. :frown:
It will no long lock and unlock the doors. It will arm and disarm the alarm though. :bang:
You can here the alarm relays kick over, but the doors don't do squat. :confused:
You can lock and unlock the doors both inside at the switches, or outside using the key, but no bueno via key fob. :hhmm:
It used to chirp too, but now if has stopped doing that. :doh:
Anyone else dealt with this?
On the same train of thought - this remote has to be closer than 10 foot to work. Whats up with that? The battery on the remote? ill go pick up at CR2025 battery to test that theory.... :meh:
Any help with the locking issue would be appreciated. :flipoff2:
brett
x2 on modifying the antenna. i've done it to 3 80's so far with great success. Quick, easy, and makes the everyday usability that much nicer.
I do not know. How can I tell? There is a box under the drivers seat that appears to be the controller. I can possibly get a photo of this box.
A picture of the key fob and the dash LED would be better. I believe all LX's came with the RS3000 alarm. The instructions for reprogramming have been posted several times. I think the electronic versions of the RS3000 manuals that I sent Christo are still on the Slee offroad web site. Check there first. If you can't find the instructions then let me know and I'll try to find them for you.
-B-
One thing you can do until you get a chance to modify the antenna is hold the key fob under you chin when pressing the button. It improves the range a little. I don't know how this works, but it does. Others here have used this method.
Here's what I'd do:
  1. Replace battery in FOB (cheap and easy).
  2. Clear and reprogram the alarm.
  3. Do the grey wire mod. :grinpimp:
It's probably not the battery, but the alarm could be arming automatically and you don't realize it.
I don't recall any programming off hand for having the alarm set but not the doors lock, but it could be there.
The grey wire mod is nice for added range. I don't think it'll help solve your problem here however. :meh:
Well
I have gotten all the docs on the RS3000 / RS3200 now, and I have reviewed the options in programming and such, and still cannot figure out WHY the door locks stopped responding to the system.
I enabled the "auto lock/ unlock" via the directions and I can tell that it took the command by the chirps (or in my case, then dull click), but they do not operate on command.
Is it possible the control unit went bad? How often have you guys seen that?
Well I have gotten all the docs on the RS3000 / RS3200 now ...
The RS3200 is a typo. The unit in our 80-Series is a RS3000.
I would look for other causes if the doors still don't lock properly. There should be a wiring diagram and an installation manual with the files that Christo had on his web site.
I would review the wiring and compare it to yours. There have been some that have pulled out the RS3000 for various reasons; probably some that have failed.
-B-
Wow, Thanks for bringing up this issue! My LX remotes have been working only at about the 8 to 12 foot range for 3-4 years. New remote batteries were worthless. New remotes and reprograming were good for only a few feet.
Today, in about 20 min I did the Gray Wire Mod. (without removing the seat). Instantly, the remotes were working at the 50-70 foot range! http://images.ih8mud.com/images/smilies/clap.gif
Door locks are still not working.
I have searched for some time, and can not find a solution.
Does anyone have any insight? The locks work fine via the door switches, just not from the alarm.
Help?
Does anyone have the RS3000 schematics? (Pin outs on the connectors)
Slee has the 3200...
OK,
here is a quick lesson:
1. You cant learn everything by reading the books.
2. Sometime just go look at the device in question.
I went to start brute force diagnosing this goofy issue and I fixed it in 30 seconds.
The smaller connector was not seated in the ECU. I reseated that connector and the locks are now working again.
Now, the chirp-er is not working, but i think that might be a good thing.
Thank you Beowulf and all others who tried to help.
Personally I like my alarm to only unlock/lock when close to the vehicle, that way the button doesn't accidentally get pushed when it is in my pocket while walking away from the vehicle leaving the interior open for pillaging.
As for the chip not working, mine only works about 1 in 75 or so tries. I'm not sure why, but sometimes it decides it wants to chirp but most of the time is does not. I should try an reprogram it to see if that will fix the problem.
... that way the button doesn't accidentally get pushed when it is in my pocket while walking away from the vehicle leaving the interior open for pillaging.
If a door is not opened within 30 sec (60 ? ) the system will rearm. This protects you against that accidental unlock after you have armed the system and are walking away.
-B-
-B-
Thanks B, that is good to know. Maybe I will do the gray wire mod now.
