Hi - I have a 3600 Kg Toyota / Denso winch on my Jap import 80. It is the 38110, which you can see a picture of at post no 10:-
https://forum.ih8mud.com/showthread.php?t=135476&highlight=winch+electric
I have just had a good look at it and it seems to be jammed. After an afternoon of swearing, I have finally unjammed the cable, which I thought was the reason for it being jammed. As you look at the winch from the front of the vehicle facing backwards, on the right you have the motor which drives a shaft that goes to the left, through the centre of the spindle upon which the spool/drum rotates, to the gearbox on the other, left hand side. After the drive has been reduced in the gearbox, it then goes to the right, back to the drum. The drum has a bearing at each end. So far so good. However, at some point in its life the cable appears to have gone outside the flange at the right hand side of the drum and had gotten wrapped around the spindle on which the drum rotates. It had got jammed between the flange on the right hand side of the drum and the casting that the motor is bolted to (very close to the 38600B part on the diagram). I have got the cable off, but from what I can see of this bearing/spindle it looks mangled and the drum is still stuck fast. In addition, I can push the gear lever down but cannot move it all the way to the right - the motor spins OK though.
Does anyone know how to take the winch apart to get at the bearing, and indeed whether it can be done? A pdf of the relevant section of the Factory Service Manual would be richly appreciated.
Thanks
Mark
Thanks
Mark
