Factory antenna parts
After thinking the power antenna didn't work since I bought the truck, I finally got around to checking out the power antenna last night, and after reconnecting the ground wire and plugging in the motor to the harness:doh:, it works!
The only bad thing about this antenna is where the mast meets the truck fender. The rubber grommet that seals out the weather and keeps the mast from vibrating around is chewed up/missing. Is this available separately, or do I have to buy a new motor assembly to get tis piece?
antenna replacement
I am needing to replace actual antenna on my 91 fj80.It got pushed over at base and is creased.It will soon break off.Iwas wondering if i can replace just antenna or do i need a whole new motor with antenna,.
I think the grommet and bezel is the technical term for what I am looking for. Anyone know if the 94 is the same antenna as a 96?
i only have the grommet and bezel not the whole thing. but if you need one i could get you a good deal on a new one.
