fab question...sort of
Wichita, KS
This may be a dumb question but I'm looking at getting a compound miter saw for home. Is it possible to run a cutoff wheel in it for the times I'll be cutting tubing and such? It would be nice to use it for both rather than get a separate cutoff saw. If it's a dumb idea let me have it.
It will tear up the saw in a hurry, and you have to be very careful that the saw will not exceed the maximum RPM for the cutoff wheel, but it is doable. I used to run an abrasive blade in an old circular saw for making longer cuts(pre sawzall/bandsaw days). It works, and I still have and use the saw, but it will take its toll on the equipment in a hurry.
So basically the answer is, if the saw is safe(i.e. doesn't exceed the blade's max RPM), then yes, it will work, but I wouldn't do it a lot if you want the saw to last.
Ary
Thanks
That's kind of what I was expecting. Since I'm not a carpenter I think I can get away with a slightly less expensive miter saw and put the $$ saved towards a cutoff wheel.
Keep in mind, the cutoff wheel I'm referring to is an abrasive wheel, like those typically found in a 4.5" grinder, but larger. You cannot run a "cold saw" blade in a miter saw. Cold saws have incredible torque output and spin very slowly.
The abrasive wheels are cheap and disposable, you will eat through a few if you do any significant cutting with them. They look just like a chop saw blade, only smaller.
Ary
