F to 2F engine conversion
Lewisville, NC
THis weekend i am about to start the conversion. other than the alternator wire, what needs to be done to get this thing working in a '69 fj-40. all advise is welcome. I am tackling new territory here.
thanks
spence
Conversion
You will need to get a different hard line for the clutch slave, I did this conversion about 4 months ago. its not too bad. I got a hard line from Napa, and just bent it around to fit where I needed it. The alt lines will need to be extended.
Good Luck.
what carb and pedal linkage do you have now? ie cable or rod linkage? what carb will you be using?
3 speed trany? if so on floor or on hump
t-case? vacuume or direct?
not sure the slave needs to be changed, mine on my 67 to 772f didn't need to be.
