F oiling info
Brevard, NC
Website
mofj40-1968.tripod.com
Searched but can't find exactly what I'm looking for.
I know a 2f has marginally more power than a F, and better oiling configuration. Does anyone have a link to or care to provide a description of how the oiling systems differ?
I've got access to a 2f with 30k documented, but have no complaints with my F that a rebuild won't fix. I'm looking at doing a rebuild or swap this summer since my F is starting to get a little tired. I'm definitely staying with a Toyota moter, just trying to get some advance info on the exact differences.
Thanks,
From what I understand about the lubrication differences between the F and 2F engine is that not all of the oil in the lubrication system gets filtered before it reaches engine components in the F engine.
Mark W. and or Mark A. will hopefully chime in here, so that this can be added to the FAQ engine information section.
What year 2F and how many miles?
If it is a solid motor with decent compression and oil pressure and you can pick it up for ...say...<$600, just do that.
JMO
Ed
Prior to '74 the F engine was a partial bypass system. That is; not all of the oil coming from the pump got filtered. In fact little of it did. A small amount of the oil was diverted through the filter and from there back to the pan. Most of the oil was pumped unfiltered back to the bearings. Eventually all of the oil would pass through the filter, but it was constantly recontaminating itself as it mixed in the pan with the unfiltered oil. If you had debris from normal wear or sludge or whatever, it would usually pass through the bearings several times before it made it to the filter (if it ever did).
The oil pump in the F engines also pushed less oil than the later 2F pump and had a more restrictive piuckup. The pressure regulator was set lower from the factory too. The later 2F pump can be retrofitted to all 2Fs.
The rocker arm oiling was a bit clunkier in the F than the 2F, but it was plenty effective.
The '74 F engine got the same upgraded oiling system as the 2F. Full pass oiling.
Mark...
2f is 1978-80, don't remember exactly which year. approx 30,000 documented miles. Price- go pick it up.
I will probably just swap in the 2f- it's sitting on a cut down frame and has everything forward of the firewall attached, including a stock Aisin carb to replace my weber.
I was just curious as to whether the advantages were more preceived than actual. I've been very impressed with my F, and it's hard to let go of a motor that has been completely reliable even though it's seen a ton of miles and very little TLC.
Thanks for the info.
