View attachment 1100933 View attachment 1100934 View attachment 1100935
I have a couple cockamamie thoughts, but don't expect much expertise from me. I've never seen that part fail on any car.
Check the back of the broken oil slinger to see if it was rubbing on the cam gear before it came apart. Also look for any gouges or marks that could have happened before it failed. If you have a hammered-on crank pulley, the pulley could have been hammered on too-aggressively. That might cause the oil slinger to crack. Your part has many small cracks, indicating a gradual failure process. The FSM does not indicate any special notes about installing the oil slinger.
The cam and crank gears don't look worrisome to me. If you want more information about how deep the cam should mount in the block, check my build thread for the pictures of engine assembly and check out a thread called "how NOT to restore an FJ40". Both show what a cam alignment looks like when the wrong plug is installed in the back of the block behind the cam. I noticed this before engine assembly, but not so lucky in the other thread. Basically, you have to worry if there is a 0.25" difference between mounting planes. Your gears look like they are within 1mm of each other, which wouldn't catch my attention. I attached FSM snips that outline backlash tolerance and gear run-out in case you wanted to check on that while you have everything apart.
