You know these are excellent questions..... I have an 81 BJ44 with the same FD pull switch. It does not light up but I hear what sounds like a vacume actuator when I pull it. I was driving on the beach a while back and got stuck in some sand... I pulled the FD switch in High gear and no luck with 4 wheel drive. I pushed the switch back in and got out and locked the hubs then put in low gear and she locked right in. I got a standing ovation from a local japanese crowd.![]()
I'm not sure about low 2, but I don't see why it wouldn't work as it will just spin the front idler without the front drive gear engaged... I'll try it in a few days. You may want to check the bulb in the switch as I really like the light on when the front is engaged...
Kraig
Assuming the FD knob isn’t needed in a BJ41 that’s been converted to a H55F transmission?On my old BJ40 the FD knob lit up when pulled for high 4wd, but was also lit up when in low range, wether the knob was pulled out or not.
