F-1 or 350chevy?
  • Thread starter Thread starter 615matth
  • Start date Start date
6
615matth
Guest
Ok, I just bought a 74' for parts and it has a solid f motor in it :) I also have a 350 with about 5k on it. My question is, do I use this f motor or go chevy? My concern with the chevy is, am I going to create problems by puting this much power on the tlc drivetrain :confused:
I have the 3-psd adapter for the 350, but if I use the f-motor I can use the 4-psd trans and t-case.
Thanks for any light anyone can shed on this.
You are on the right track. You will need to do a lot of mods for the 350. It is a worth wile undertaking. It just depends how much money and time you want to put into it. The coarse splined axlex wil not hold up to the torque.
Anothe option you could put in a ranger torque splitter and be able to use the 4 speed and transfer and use the stock driveshafts.
I was lucky I bought mine with all of this done. My 71 has a 78 drivetrain under it.
Ups for the 350 is parts, weight, and torque. You can get pearts cheep for the 350.
I say stay with the origional F, you just can't beat the way they sound, run, and I prefer to keep it stock and origional styling. The choice is yours: origional setup where everything is doing fine (I'm assuming) or take the risk and put in new engine and other parts. When adding more and different parts things will go wrong. It really depends on what you are going to do with your rig. If you are going to rock crawl, 350. If it is a daily driver or light to moderate off-roading like power line trails, logging roads, etc., keep the F because that's what it was designed for. I say F, but your call. I won't judge you either way. :beer: :beer:
