ez-wire question-
crosspost..
I clipped the AC compressor wire on my EZ-wire 21 circuit harness up in the dash at some point and am trying to track down the other end on the fuse block side. Ofcourse I cant find it. I am trying to figure out if it should be tied directly into the fuse block or or off another wire? Does anyone here know?
thanks!
Dustin
dustin said:
crosspost..
thanks!
Dustin
I'm not an expert by any means, but I'm in the middle of wiring up a project right now using the EZ21 harness.
I don't believe the compressor wire is hooked to the fuse block. I think it is just floating dead in the harness right now. I hooked that black compressor wire up to one of the 2 wires coming out of the compressor and the other end went to 1 of the 2 wires on the pressure switch.
Hope that helps?
Matt
thanks man. I ended up tieing the wire into the heater power. I tried so hard to keep this harness neat when installing, but once its in there its a rats nest to go through and find a possibly clipped wire.
thanks!
Dustin
