Extreme Passenger Lean
Feenicks AZ
So i spent all day today wheeling, when I got home I realized that my front passenger side was noticeably lower than usual. I measured from the center of the hub to the flare. 18in on the passenger side, and 21in on drivers. I looked around and couldnt find the cause, didn't see any missing bushings or anything. Is it really possible that I wore 3 inches off just the passenger spring in just 8 hours light to medium wheeling?
Measure the springs and compare numbers. Also, the angle of your front tire and the birfield look a little suspect but maybe it's just the pic. Tires inflated the same?
I measured the Springs too, if I remember correctly they were 11in on passenger side and 13 on driver. And I hope that is just thr picture, I didn't notice an angle when I was taking it, I'll check when I get home.
If those are stock springs, which it looks like they are, then maybe they are fatigued and couldn't handle heavy flexing. I'd clean them off and look closely for any signs of stress cracks.
Will do, thanks. Luckily I'm getting a lift soon. And btw I just got home and checked the tire angle, it was just the picture.
Look at the base of the spring. To me the lowest coil is broken or bent. The coil spacing should be very even through the whole spring. Time for new springs.
Did you bend a control arm? That would show up this way too possibly.
