Extra fuel tank ?
I have a question for the Aussie crowd regarding an auxilary diesel fuel tank I picked up from an Aussie HJ60. It is a TJM 35 gallon and fits between the inside the left frame rail and the rear drive line and between the transfercase and the rear diff. My question is what do they normally do to modify the exhaust system since this tank sits exactly where the exhaust pipe and muffler normally sits? Any advice is appreciated.
Got some pics of the tank? Thats big for an auxillary tank:smokin:
I dont know exactly about yours but sometimes you have to reroute the exhaust by crossing to the other side,right behind the t/case.
I would install the tank and see what you have to work with unless someone has a definate solution.
Your exhaust runs down the left side all the way,right?
You might get more answers on Outer limis;)
Fuel tank
Yes, my exhaust runs the entire length of the left side. This is a very large tank and it measures 45.25" (1168mm) long, 21" (533mm) at the widest and is 8.25" (210mm) deep. It would fill almost the entire area from the tfc to the diff. It doesn't appear there would be enough room to bend the 3" exhaust to fit it between the tank and the tfc. One fella on Outer Limits posted a photo of his and he had to route his 2F exhaust under the frame rail and then it looks like he followed the outside of the rail to the rear. His 2F had a much smaller exhaust pipe this this 3" on my diesel. This might be what I have to do but these TJM tanks being so popular down under I am hoping someone can offer a better solution. Got the tank for a very good price and if I can get things figured out I will convert this rig to a duel fuel machine. 35 gallon vegatable oil and 24 gallon diesel capacity should get me somewhere at a lot less expense.
