Exterior plastic vent fix?
RDU, NC
On both sides of my 80, the exterior plastic that covers the vents behind the cargo area windows are broken - the peg at the bottom that goes into the body sheared. The whistling is driving me nuts.
I'm thinking some super-duty Goop or other adhesive might be the best fix. Or perhaps drill it out and run a screw through w/ a small washer on the outside?
I had the same problem with my drivers side vent. It was loose so I just tried using black silicone, but that didn't really hold to well. Then I went to pull it totally off and didn't realize a screw held in on too, so it tore a small hole in the vent where that peg was. So then I used a screw all the way through to the inside with some rubber washers which worked fine, but I didn't like seeing the head of the screw all the time.
Finally, I ended up getting a used vent in good shape, from a board member, to replace it. I think this one had a clip holder cracked, so I used some metal grade 2-part Epoxy to hold the upper push in clip on.
I never noticed any whistling from it at any time though.
