Extended tip spark plugs
MA
Has anyone tried extended tip spark plugs in the 1FZ? They show gains on the dyno of several hp on the little 600 and 1000cc high strung crotch rocket and snowmobile engines. Since the 1FZ seems to show some gain by advancing the distubutor timing, these sound like a viable upgrade as they have an effect similar to advancing the timing...
Just google extended tip spark plug... they're nothing new. Most companies produce them, NGK, Bosch etc etc. Many oems spec them for their engines. One of the reasons they work (on some engines) is because the tip of the plug sits a little further into the combustion chamber. When it lights the mixture it begins burning that much closer to the piston which is rushing up to meet it... it's similar to advancing the timing. With that said, some engines don't like them or simply don't need them.
So guess which type of plug everyone with a TRD Supercharger installs? One may think the one heat range colder prevents preignition and such. However they are very likely part of keeping emmisions in check, too. Extended tip plugs also act like a hot plug at low speeds and a cold plug at higher rpms.
I have no expererience with extended reach on the FZ. On my other car with a non-force induction engine, it produces no noticable change in pre-ignition prevention nor HP increase, although others with the same engine rave about the improvements.
no experience with extended tip. I do run the denso iridium plugs in my naturally aspirated rig. I noticed a difference when i put them in.
