Extended brake lines
perth wa
So i have got a lift kit I want to install on my 105 series Landcruiser 1hz and I need to install the extended brake lines but can’t find any info on how to install them could anyone point me in the right direction?
Do you have a manual? Which part of it do you need to know about ? Brake lines are unscrewed and replaced, then topped up with new fluid and bled. Bleeding starts at the furthest from master cylinder and there will probably a Load Sensing Proportioning Valve (LSPV) above the rear axle that also needs a bleed.
Unless the lift is more than 50mm , you don't necessarily need new brake lines.
