Extend tds alarm range
Lenoir, NC
I've searched and searched for manuals or a writeup on how to extend the crappy 5 to (at best) ten feet of range on the TDS security system on 80 series Land Cruisers and found zilch good info on it. So I decided to trace the red led button on the left side of the dash back to the alarm. The Security module is not beneath the seat like most Lexus applications and the RS3000. It is sketchily zip-tied way up under the dash above the driver kick panel. The antenna is (for some reason) wrapped around the module which is mostly blocked by a dashful of sheet metal. I removed the zip ties, unraveled the antenna and did some brainstorming. You may not need to go to the extent I did, and you can probably just route some 14 ga. wire up your A-pillar and extend the range a good bit. However, I decided to do some GRADE A ;-) rigging and used Amplifier power wire. I stripped the antenna a good ways, wrapped it around the 2ga. power wire and soldered and covered with electrical tape. I then proceeded to mount the power wire under the kick panel and around the sides of the whole vehicle under the door sills and carpet. Once I had tested and re installed all the trim, I had a range of more than 100 ft. I have also had the battery in my remote unlock for a while so it is probably weak. I will replace soon and update you guys with the results. Any ideas or suggestions or other comments are greatly appreciated. Oh, also... the shock sensor is zip-tied right up there with the module and it has an adjustable dial to increase or decrease sensitivity. Hope this helps.
-Zack Wheeling
'97 Land Cruiser Collector's Edition
hey ebag333 were you saying "sounds like a different alarm system" to me or to nlxtasy? lil confused :-/
oh, another little PS, the antenna on the TDS module is black and not part of a wiring harness but a lone wire sticking out of the module. not a grey wire mod...
To nlxtcy.
Sounds like a similar mod, just a slightly different method. Too bad you didn't take pics while you had it open.
