Expotundra's 2003 Tundra AC TRD Build
Triad, NC
So about two years ago I stumbled onto this 2003 AC TRD. It had 35k at the time on the clock and now has approximately 46k. Long story short I planned on doing things quicker but life got in the way and I just enjoyed having a reliable truck.
I finally got the 5100s and wheels and tires over the past few days and here is how that panned out so far:
Ok, so my 5100's came in along with the wheelers steelies. After much gnashing of teeth and tossing and turning at night in bed I decided on 265/75s. Yeah, I might go larger later, but this is a pretty nice upgrade from where I was and honestly I like not having clearance issues. But alas, they are just tires and do wear out...so there'll be more time for me to go larger later.
Anyway, I also ordered the black lug nuts and gorilla locks in black while I was at it. I also purchased the diff drop though I have not installed it yet.
The install of the shocks went pretty easy...well, as easy as it can go doing it by yourself without air tools. Couple tips for those of you doing it in the future:
For the fronts: make sure that the top nut is cranked all the way down before trying to get the assembly installed. I thought "ah, it won't be a problem and I'll tighten the top nut after the weight of the truck is on there". Well, it was a problem and was a pain in the butt to get the bottom bolt in. Also, I just installed the bolts with the nuts to the rear instead of to the front like they were from the factory. If anyone knows why this would be a problem let me know, but it was much easier. Also, the spring compressors you rent from auto parts stores don't work well on the tundra springs (I'm reusing stock springs). But they did work, it wasn't fun though. If I were doing it again I would just pull the assemblies and take them to a place that had a proper spring compressor and let them do it in five minutes. I read this advice before and thought "Nah"....but trust me it would be easier.
For the rears: I would like to start off by saying that I hope the sonova***** that designed the top of the shocks to be so inaccessible catches the seven year itch. With that out of the way, the bottoms are easy...the tops are not. Do yourself a favor and grind flat spots on the shafts or do like I did and weld a scrap piece of steel to the shaft so it hits something as it starts to spin. This was really easy and made things go quickly....or as quick as was possibly while still having to mess with turning a wrench in such tight quarters. Oh and if you don't have a ratcheting box end wrench GET ONE. Stock top nut is 14mm, 5100s top nut is 17mm.
I took measurements along the way and pictures as well. Prior to the change I had 265/70s and completely stock suspension. Here are the measurements to the bottom of the fender wells. Oh, and this is listed in the order that I did the mods. I installed the fronts last night, got the tires on this morning, added the rears this afternoon. Also, if I didn't mention it I went with 4th notch up, which was supposed to be 2" of lift:
Stock:
Front: 34" Rear: 36.5"
After front shocks installed:
Front: 36.125" Rear: 36.5"
After new tires:
Front: 37.25" Rear: 37.125"
After rear shocks installed:
Front 37.25" Rear: 37.25"
Prior to mounting the wheels up I measured my 265/70s which were fairly worn and they came out right at 30". The new Goodyear Duratracs in 265/75 measured at 31 5/8". Obviously this was not with the weight of the truck on them but I thought it was an interesting comparison since the tacoma world tire calculator put the 265/75s almost exactly at this size but the 265/70s were listed at .6" under what mine were....and I don't think I had .6" of wear. In any event, I'm super happy with how everything turned out. Now I just have to get an alignment this week. I also noticed that I have a torn steering rack boot which I will have to deal with also. I may just have the shop do both at the same time so I don't have to fuss with it.
Here are some pics in the same order of the measurements I listed above (stock no lift, fronts installed on factory wheels/tires, new tires installed, and rears installed):
I also hose clamped the front CVs while I was under there. I added a breather line for the rear as well. For the breather I just got the proper fitting, installed it on the housing, used some 3/8" line, ran it up by the frame and to the area behind the driverside taillight. I terminated it with a fuel filter that had a 3/8" nipple. I used this technique with breathers many times before and it keeps junk from getting in the line but allows air to flow. If you do this leave slack above the axle to account for droop. Here are some pics:
Here are the final pics of the truck as it sits now:
Any questions just ask. I think next up will be deciding if I'm going to install the diff drop. I need to do some tune up stuff here soon as well...
Thanks for stopping in.
turned out nice! fuel filter is a good cheap alternative, good idea! i'll be putting 5100's on the front soon, already put rears on, but I didn't read where you installed the clip for the adjustable coil mount on the front shocks, is it in the middle? Does it ride much rougher now? I was curious what the best tire size would be and I think you nailed it in my opinion, hopefully won't affect mpg much.
