explain the smoke
Sorry, the rig was not readily available till now, To answer some questions , it is a 2f engine I believe a 78-79, it[ does not smoke at all other than on an incline , not even at start. The pcv is not at the top of valve cover and i believe it is on pass side below head, I will today replace pcv and start there . I dont have a compression tester but will get one and check that..heres a pict of motor
Just like in a 60, the pcv leads into the intake. If it doesn't smoke at any other time then its probably not the valve seals. Hopefully the pcv fixes it!
What carb is on it?
borrow a compression tester...i believe you can rent on at your nearest kragen or autozone...
