Experts opinion: Engine/Transmission interface leak
San Diego
My vehicle has transmission fluid leak from where the engine mates up to the transmission. There's a weep hole where the two interface and there's a constant dripping of (red) transmission fluid when the vehicle is good and warmed up.
The plan is to drop the transmission enough to replace the front input shaft seal,
But nowhere can I find a part diagram that shows the front input shaft seal for the A442F transmission.
Ultimately, I'm looking for the part number for the input shaft seal if it's even called that.
Yes, I know... while it's opened up, might as well replace the (engine side) rear main seal :cheers:
Can someone help me out with a part diagram and part number for the (transmission) input shaft seal for a '94 A442F tranny?
Thanks....
Also... what else can be leaking from that interface?
The seal might be called a "pump seal" or similar. At least, it will go in the front of the pump where the torque converter pokes in. Also, there is probably an O-ring around the outside of the pump, where it meets the trans housing.
Those are the two most likely candidates for an ATF leak, in my mind.
SUMMIT AND I Lean... thanks guys. I found the parts and got her all fixed up. Rear main seal and transmission pump seal. Now leak free!
So is this the rear main seal leak?
For further clarification, post a few more photos from different angles.
Looks like rear main seal could be seeping bit it could also be from the pan seals. Maybe the upper.
More photos in daylight.
Mine was literally dripping out when the engine was on. Rear main seal was dripping slightly, but the input seal to the transmission was gone. I was losing a couple cups a day.
