Exhaust Relocation Questions...
Portland, OR
I am in the process of building a rear bumper and now realize the build will be A LOT easier if the exhaust is out of the way...what i want to do is re-use the resonator but lift it all up above and between the frame rails...i was looking around a bit and it seems it has been discussed a little about exhaust gasses but curious what others have done.
what i am thinking it to have a tip bent down towards the ground then out towards the tire trying to keep it as high and tight as possible. went to a muffler shop and he did mention i may have a exhaust problem but he was not for sure it would happen...anyways only about $75 to relocate, new pipe and new tip!
comments?
thanks
barrypt5
Well i was hoping to get a response but.......i think i have decided to route it under the frame and out. A lot of people i work with talk about the CO issue and with a new family member on the way i think that will be the better choice. so i plan to still get the resonator up above the frame then just angle the exit right out behind the tire. I guess search was my friend on this one :doh:
barrypt5
FWIW, I had my exhaust bobbed by about a foot, which meant losing the resonator, but I haven't missed it. As far as I can tell, the only thing the resonator did was to mute a mild whistle under acceleration.
I'll admit I did not do a search on this. Do I have a CO problem? I don't know. Uh...what was the question again? :o
You could just remove resonator and trim back then add the resonator on the inside of frame rail IF you lose the factory spare tire bracket. If your willing to lose this, then you can get it in tight.
and i have since gone back and added a resonator in the straight sectiton b/w where it goes over frame crossmember and where it parallels the frame.
