Will an exhaust leak reduce fuel economy in my 1fzfe? How soon should this be fixed? And while I'm at it I was going to dump the pipe out the side behind the rear axle. Thoughts?
Thanks
It depends on where it is. If it is after the second oxygen sensor I don't see how it could affect fuel economy. If it's before the second, or worse before the first (fuel/air sensor) then definitely yes. If so it's better to fix sooner than later.
You can dump out the side behind the rear axle, but beware that you are NOT close to any of the paint. the exhaust out of these truck are hotter than anything else I've ever driven. I had the exhaust on mine melt a wheelchair tire on the rack behind the truck, about 14" from the exhaust on a 1 hour drive in 95*F weather. At idle, the exhaust will track up the side of the truck and may cook the paint or any trim in that area.
