Exhaust Chop Q
Los Angeles, CA
Website
www.phipsi.net
Is it acceptable to have the exhaust end at the mid point of the truck so that the exhaust would not be directly existing the truck, rather the fumes would be under the truck. I want to cut it right after it passes the 2nd mount point after the canister. I've heard that exhaust fume over time are not good for the belly of the truck...can anyone prove or disprove this?
I would angle the emission toward the floor...would this have an affect on Smog?
I hope I was clear, thanks in advance
OK, let me see.
Mid ship exhaust was a big thing in the 70's when we wanted to try cheap stuff to make our cars sound "better".
Fact is the bottom of the car is not the worry, it's all those fumes you suck into the cabin that becomes a bit of a problem.
Run it all the way to the rear of the truck, you and your passengers will live longer.
I saw where someone once had it exit right before the rear tires out the side.
I don't like the smell of exhaust (or the idea of inhaling COx) so I would never do anything short of having it exit out the back.
It is still exiting the back just not all the way in the back and not ported out to the side. I don't think it would be an issue for those in the car... unless I was to be at idle for a long period of time with the windows down...So I guess it's a health issue if anything....thanks
Sam, that is what I have done on mine. I have a 40 series flowmaster and it was not loud until I cut it off after the muffler. It will be LOUD in cabin. You will also get a bit of carbon build up on the shock and spring etc up the truck. I am thinking of bending a little piece to have it exit just in front of the right rear tire to kill some of the resonation. If you cut it off keep the tail pipe as you may end up welding it back on:cheers:
Like Los Angeles traffic???
and I think you may run into trouble at your next inspection.
Not a good idea. Getting sick from exhaust fumes is a really bad deal, best not to mess with it. The area between the frame and the body is one big low pressure area even when cruising through LA, all those fumes will stagnate there and find a way into the cab. Do yourself and your passenger a favor and come up with another plan.
Keep this in mind...Guys that run short exhausts that terminate under the vehicle will end up looking and acting like Joe Dirt :D
I've had mine cut off right next to the rear passenger wheel for almost a year with no complaints. A little bit of a whistle at higher rpm's, but have never noticed an 'exhaust smell' or heard complaints from passengers.
I knew all it would take a one sided answer to get you guys to wake up...thank you...I"m going to consider what you guys have said in thinking about what I want to do...my initial reason is b/c I have rattle the poin at which the pipe crosses over the rear most horizontal frame post.
Why not take it to a good shop and have them adjust the hangers?
several reasons...most of which are excuses, but I'll state them anyway.
-No time since this is my DD
-Although it's cost would be low I have a whole list of need to buy/do items many of which are priority over the truck (I know what am I thinking)
-I want to eventually replace the pipes exhaust and move the whole exhaust up higher/ and turn the cats since I have the body lift.
- might just solve it temporarily and weld a bracket in the rear until I get to do it the way I like.
:beer:
Mine rattled after the last exhaust that was installed. Until tomorrow when the system gets replaced I used a piece of silicone baffle seal ie mat material (~1/8") and ty-wrapped it to the same section of frame you speak of. If you're interested I'll send you the pice I have since I won't be needing it and it's still good. You'll have to supply the ty-wraps. If nothing else it'll quiet things down until you replace the system.
