NEED HELP
97 LC 110k
I have owned this truck for 1.5 years now. The 1st thing I did after I bought it was check the fluid in all of the boxes. This was a lease vehicle to 1 person before I took ownership. All fluids were full and looked extremely fresh. This truck is very clean and obviously well maintained. When I was checking the fluids/greasing everything I noticed I could grab either of the drive shafts and rotate them quite a bit more than I thought I should be able to before locking the rings and pinions together. I am talking almost a 1/4 turn and they turn together (no play in transfer case). Since I never had any vibes or leaks I was not concerned too much. I installed the OME lift and 305/70 toyo mts....still no vibes or problems at all.
Last week I installed a rear Aussie locker (everything within spec original thrust washers used) and now I am having an issue that is driving me insane. When I am driving, if I decel or let off the gas and reapply the throttle I can feel the movement and it is very obvious. Not a bang, but definitely extremely ANNOYING. I figure with the locker that the play does not have an exit like it did with the open carrier.
Anyone have any ideas? Do I need to replace ring and pinions? I have removed the driveshafts...the play is there.
Any help is greatly appreciated.
Patrick
97 LC 110k
Patrick
