I have the famous "insufficient flow" code. It's been on for about 4 months. I plan on fixing it, but just haven't had the time. This past week, I was rolling down the highway and the oil light on the dash pops on. I instantly put the truck in nuetral and killed the engine. I didn't even take time to glance at the oil pressure. I pulled over and checked the oil. It was a little below the full mark (about 3/4 up from the low to full mark). I always carry extra oil in all of my vehicles, so I topped it off. When I started the truck, everything seemed normal and the light was out (the oil light, still have the CEL). Would a malfunctioning EGR cause excessive oil consumption? When I topped off, I added 2 1/2 qts. I did a compression test on it a while back and compression was good and consistent across all cylinders. I'm thinking my EGR is causing me to burn more oil. Any and all comments are welcomed.
Additional details: 1996 LX, 150K, all stock plus an aux. fan., I run full synthetic and change every 3k.
truck, but that had less oil use than mine (by about half) to start.
