Here is a pic of the eecd for GetsUThere. It't the line with the diaphram connected to it. Can this be plugged off or do I need to try and repair? What is best repair if necessary?
This rig does not have a fuel return line any longer. PO installed a short block chevy.
What you've pictured there is the Fuel & Vapor separator. It's connected to the fuel tank on one side and the charcoal canister on the other side. If I understand properly, it looks like what's broken is the check valve that goes to the canister. This stuff collects vapors from the tank and passes them to the canister so they can later be reburned. The check valve actually passes both directions. When the tank starts building up pressure fuel vapor flows out. When the tank pressure gets low, it lets in fresh air via the canister.
It's hard to see exactly what you've got there, but assuming what you're saying is that the check valve is broken, you probably don't want to plug off. If pressure builds up or drops and your tank has no way to equalize that pressure, it can potentially deform. You also probably don't want to leave it disconnected floating around inside the cab, since you'll fill up the interior with fuel vapor.
New question... do you still have the canister and is it hooked up to anything? If so, personally I'd attempt to repair or replace the valve and make it work properly again. If you don't have a canister, I'd say run the line out of the cab and let it vent to atmosphere. (Note this is bad for the environment). I vaguely recall that these valves are still available from Toyota but cost around $40. You might be better off looking for a separator with the valve on it in the parts wanted/for sale sections or ebay. I see those drifting by on ebay every once in a while and they rarely bring much.
Thanks for the good explantion. If you look closely at the picture you will see the bottom nipple on the left baffel or tube is broke off. Hard to see. Actually the check valve is ok...just disconneted. It appears to be in tack. I just have to repair the bottom left tube so I can reconnect the fuel line. I found it broken clean off when I went to remove fuel filler neck for cleaning and rust removal.
From your explantion looks like I do need to try and repair nipple or else truck will smell of gas vapors.
