EVAP/Charcoal canister
Georgia
I know this has been discussed several times, but thought I'd share my experience in hopes that it helps someone out there.
Backstory: Purchased my LC a few years back, and immediately had to deal with the evap canister due to the pressure releasing when opening the gas cap. Saw the forum for the Duralast VC120 so I did that swap, no issues for the remainder of the years I lived in GA.
Moved to TX and now I'm seeing temps that are 100+, and started having the pressure AND now also a really bad fuel smell that would often get in the cab when idling, would stink up the garage, would make people not want to ride with me, and was just not ideal.
My THOUGHT was, it was duralast, not OEM, so maybe it went bad SUPER pre-maturely since I don't trust their stuff ANYWAY.
TEST 1: First thing I did was get a new VC120. Figured "what the heck", $120-ish and if that fixes it again, then so be it. It didn't fix it. This time I even made sure to try to rig it up with the stock mount (didn't do that before) thinking MAYBE there was something about the vent on the bottom that caused an issue.
TEST 2: Since that didn't work, I swapped out the VCV, thinking maybe THAT wasn't doing it's job. (yes, I know there's ways to test these things without throwing parts at it, but I figured it's 28 years old at this point anyway, might as well swap it while I can find the part). I purchased from City Racer LLC (highly recommend) and it was like $59 instead of the dealership wanting $185. Doesn't look like it's available from City Racer anymore but the part number was 90925-03192. This didn't fix it.
TEST 3: I had seen on some forums that SOME people were able to get it resolved by swapping the gas cap. Cheap enough, figured I'd try it. Dealership wanted a ridiculous amount for that so I'm going to be ordering it, but in the mean time, I got one from Autozone just in case the cap IS/WAS bad and honestly I actually like this cap so I'll probably roll with it for a bit. gas cap
TEST 4: I started digging into our EVAP systems and the state of fuel today and I came across something interesting while researching this. EPA issued a temporary nationwide fuel waiver this summer that allows higher-volatility gasoline than is normally permitted in some areas. Higher-volatility fuel (higher Reid Vapor Pressure/RVP) produces more fuel vapor when it gets hot. I’m wondering if that, combined with 100°F+ ambient temperatures, is overwhelming the older EVAP systems in our 80s and contributing to the tank pressure and fuel smell some of us are seeing. I’m not saying this is the cause, but it seems like a plausible factor worth considering. Link to EPA nonsense. At this point, I also started playing around with only filling up with non-ethanol fuel. It SEEMS to have made a difference, but I still noticed a BIT of fuel smell and a BIT of pressure in the tank.
TEST 5: At this point, I'm getting more convinced that this is a limitation of our EVAP systems and the ethanol and RVP garbage is pushing the limit, but I'm determined to figure SOMETHING out. So I go to the store and get ANOTHER evap canister, but this time I go with This one. Instead of the VC120 venting into the engine bay, this one has a vent port like the OEM style (but on top instead of the bottom), and that way it can be routed away from the engine bay. I couldn't imagine this would do anything for pressure, but figured MAYBE it would help with the fuel smell. SOMEHOW SOMEWAY, this seemed to be the answer. I don't see how it makes a difference since it still vents, just out of the bottom now instead of the engine bay, but I'm telling you, I've been beating this thing up the last few days testing it out, driving in hot temps for long periods, idling in direct sunlight for long periods, doing everything I can to reproduce the fuel smell and pressure that I've been having, and I finally have none of it whatsoever. It honestly makes me a bit annoyed because I don't see how it makes a difference, but for me, it does, so I'll take it. I did NOT use the OEM brackets for this one, it's thick like the VC120 and I was already annoyed that the longer bolt and nut workaround to get the bracket to work, somewhat impeded the lid to the fuse box, so I actually just kinda sat this one in there, kind of wedged up against the wire loom and left it. Hasn't budged at all. If I get bored I might zip tie it like it did before, but for now I'm able to let this one just sit and not worry about the venting from the bottom.
TL:DR -
Want to try a new gas cap and get one TODAY? Duralast Gas Cap
- Want to replace the VCV? Part number: 90925-03192
- Want to try non-ethanol fuel? Non-Ethanol stations (there's also an app)
- What fixed it for me? Evap canister with OEM-like vent
  • Like
Reactions: cts
Or modify your OEM by following LCP instructions (drill out the BB)....$20 new charcoal and $6 epoxy. Works for us. 😉
x2. Exactly what I did. It works and it's a 1/2 banana job.
@efjayatee @Old Nick I still have mine and plan to do that some day, but I was already angry with it being 106 outside and working in the garage so I just threw something on. But also, not everyone is going to have the OEM still or be able to find/afford buying one.
TL:DR -
View attachment 4204233View attachment 4204234View attachment 4204235
Thanks for being a excellent guinea pig!
Seriously. I do believe a part of the answer is in the fuel blend.
On a hot day in July I was weed whacking with my 2 stoke and it stopped and wouldn't restart. When I opened the gas cap to check for fuel it had enough but it had bubbles. I didn't think much about it and figured it needed a carb job.
A few mornings later I thought I'd try it before tearing it down.
It ran perfectly fine.
100% the fuel didn't handle the heat.
May all your trails be happy
hahaha happy to help.
Originally I thought there was no way it was the fuel blend. I hadn't been in THIS hot of temperature yet in my land cruiser, but I've driven it between GA and TX several times so it clearly would have been hot and never experienced this issue. But when I saw the notice from the EPA that they changed the allowances in the fuel, that made a lot more sense and then for the evap canister itself, it's odd that I wouldn't smell the fuel smell with the hose routed towards the bottom because regardless, it's still venting, but for whatever reason, the smell has been completely gone with the new can.
And I had previous experiences as you with my lawn mower and never once thought it was the fuel. Always figured it was the damn carb. I also have a 71 firebird and I've been having a similar issue and that thing ALWAYS runs hot so I'm probably going to do better at putting non-ethanol in that as well.
Man, no worries. Time, heat, you name it... sometimes going the straightforward route is exactly the way to go. When you get time, restore the original as your backup and you'll be good to go.
I've always had a similar thing when opening the fuel cap with it sucking in a heap for quite a while every time I fill up. I could think of it maybe damaging the fuel pump with it having to work harder against the negative pressure but is there any possible harm further than that? It's on the list, just deciding on its position based on urgency lol
