Ethanol?
Does anyone know what 10% Ethanol blend gasoline is going to do to our engines? Most stations are using it in our area. Can we run higher % Ethanol without damaging our engines?
Thanks, Terry
Does anyone know what 10% Ethanol blend gasoline is going to do to our engines? ...
Our "winter gas" has 10%, the only effect that I have seen is lower gas mileage.
E10 will not have any adverse affects on the engine. Mileage, based on energy content could be down 5-7%. One benefit is it will clean up your fuel system, some deposits, and dry out your fuel system nicely. It is not recommended you run any ethanol fuels above E10. You could probably run it an E20 with no real problems, but I would not as it is not recommended for seals etc...Get used to it folks because if you do not have it now, you will, and that is everyone, eventually, over the next few years...
Doesn't E10 defeat it's own purpose of "lessening our dependence on foreign oil" if by using it your mileage goes down and inturn you buy more gasoline? You still wind up using the same amount of foreign oil, right?
Sorry for the rant...............................
It is a negative in my book. Think about how much fuel is used to buy the corn seed, plant the corn, spray the corn, harvest the corn, haul the corn to a dryer, haul the corn to a distillery, run the plant that make the ethanol, haul the ethanol to the mixing plant, etc.
You can insert any plant of vegetable in place of corn.
If I recall correctly, Henry Fords first cars ran on ethanol. Poser would know for sure,
I just got back from a trip to the Rockies. Loved it out there but it is good to get back to Michigan with our "normal" gas (87, 89, 93 octane). Most stations in CO had 85 octane, 87 octane with Ethanol, or premium. I didn't want the Ethanol but also didn't want 85 octane so ended up spending the extra money on premium.
Do people use the 85 octane in their Cruisers?
Henry Fords first cars ran on Hemp oil, or an alcohol made from hemp... Hemp is illegal for more reasons than just one, imagine if everyone grew there own fued from weeds in the back yard, clean abundant enery... it's a wonder why marajuana has been illegal for the last 100 years.... Hemp hearts are high in protein and a good source of fibre too...
And as far as ethenol goes any vintage sledder will tell you it eats crank seals, causes precumbustion/ignition issues on 2 stroke sleds... On a two stroke the timing needs to be retarded to run even E10 properly... I haven't herd of many negative effects on car engines... someone from brazil would know better they run higher ethenol blends from there sugar cane....
http://www.hempcar.org/ford.shtml
http://www.hempcar.org/petvshemp.shtml
Yes, out west I use 85 octane 100% gasoline, and I get better fuel mileage w/ it than with 87 octane 10% blend, fwiw...
I am currently on my first trip to "the West" - so this is my first time with 85 octane. As per the Scangauge, I got almost 18 mpg - I usually only get 14 or so with 87 octane no ethanol back home. Part of that 18 mpg trip was through Wolf Creek Pass too!! I was down to about 15 mpg at the top, but by the time I coasted down, it was showing almost 18.
Tony
