Error message when trying to upload an image file
Maryland
I'm receiving an error message when trying to upload an image file. The counter never moves past 0%, then after about 15 seconds I receive an error message. It won't even let me upload a tiny 22.5kb jpg of the error message. If you want I can post the error message to imageshack or elsewhere and try to link here. It looks like a generic error message.
yes, if you could post the message, that would help...there is nothing in your user settings that should prevent uploads.
This is a 4mb file, uploaded without issue...
I get that same error trying to upload an image file using Firefox 27.0.1. The error does not occur using IE or Chrome.
To fix the problem: un-check "Use the Flash-based uploader to upload attachments" in Preferences
Or use this workaround, here is the sequence:
Click "More Options" to begin
Click "Upload a File" and then choose a file to upload from the file browse window, click "Open" and this error is returned.
After closing the error message window, this screen appears. Note "Attached Files:" under the 3 orange buttons. This did not appear on the prior screen. Click on "Attached Files:"
and this window displays. Click "Browse" to find the file to upload. The file browse window will open, select a file and click "Open"
The attached file will appear in the list. To add more files, click on "Attached Files:" and repeat.
