Envoy engine into cruiser?
Really?? They were first designed in 1995 by GM in Michigan. First used in a baja 2000 race truck (winning that class that also included V8's in it) and first put in a production vehicle in 2002 for the olds bravada. Made in Flint Michigan.
Fail to see the Isuzu part of it besides being used in Isuzu vehicles.
If you go the non-Toyota route, I'd like to see one advantage the I-5 and I-6 have over a small block Chevy. The SBC has more power, more torque, more aftermarket support, adapters available to install into an 80, plug and play wire harnesses available, and can be found cheap in junkyards everywhere. I drove an Envoy once and was unimpressed with the straight-six, the rest of it was total crap.
Plug and play wiring harness for a SBC swap into an 80-series? That's something I haven't heard before, but would be interested in seeing more info on.
The 5.3 is an excellent engine for most cruiser swaps, but my main concerns are not making the most power. I would like to drive my cruiser on a regular basis and haul my gear fishing and hunting, I don't need to push 35+ tires around and rock crawl or tow large loads. I just want an increase in power and fuel economy, plus, I like the idea of replacing a straight 6 with another inline engine. It looks like it belongs in the engine bay.
After looking at the I5 atlas swap thread again and seeing the pictures of the install, I'm beginning to really lean in this direction over the various diesel swaps I was looking into. Cost of this swap seems to be reasonable in comparison, especially given the cost of a low mileage or rebuilt toyota diesel.
If it is an engine swap you want i'd say go for the I5 as that guy has already done it and could help you with trouble shooting.
I think this has been said. Swapping in a gas engine for another gas engine is kind of pointless. A diesel is the only way to get power and mileage that we desire. I know going that way is expensive but i feel any real diesel will make the beast come alive.
I think it means he would never want what is wrapped around that engine from the factory.
Bingo!
It's not quite THAT easy, unfortunately. Painless Wiring has a number of standalone engine harnesses with ECU designed for swapping various engines into hot rods, etc. Basically you provide power and this harness does the rest. It would make for a much easier integration of a swapped engine than trying to splice the wiring harnesses together. Of course, they're also over $1000, I can do a lot of splicing for that money. Page is here: Painless Performance: - Fuel Management Systems For Customs
Bingo!
Yep we used one of these in my friends 68 SS.
Got the engine and tranny (6spd) for about 1k
Engine management for about 1K (plus a way to tune it)
A bunch of used peformance parts off of LS1.com for about 2500
Result was about 590HP and 680TQ for under 5k.
Engine has 165k on it and hasn't has as much as a hiccup on it yet. Runs like a champ.
I would go the I6 because 80s are heavier. 06-09 have 291hp/277ft./lbs I'm planning to do one in a 60. You will need to lift it because of the oil pan (so now you have your excuse for a lift).
Here are some links. Hope they help:
4200 engine swaps + hot rod parts - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
GM Vortec engine - Wikipedia, the free encyclopedia
engine weight - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
To source one search here: Car-Part.com--Used Auto Parts Market
Good luck and post up on your build!
5k can turn any vehicle to a monster especially a 1FZ. A turbo system is way cheaper. 5K will build you a race motor. I agree it would be easier to do it on a chevy unless you are educated on how the 1FZ works.
The last turbo kit I saw for sale for a 1FZ was about $9k installed. Who will build you a race 1FZ for $5k, and what is the output of this mythical motor?
9k for a kit. Wow.
All this motor ever needed was new pistons and rods. ross, je , or crower will fit the bill. I wouldn't boost a 1FZ without a standalone and a better knock system. It just doesn't make since to boost a non Forged engine if you know it will kill the motor. It is cheaper to upgrade working motor than a broken motor. If you have broken your 1FZ( hole in block), it would probably be cheaper to get a chevy. 1FZ are expensive from wrecking yards.
Engine management can be done with Emanage or anything in that price range(motec is expensive). Im still working on a cheaper and better way of controlling the engine. Turbo kits have been done for cheap on this very site.
The trans is where my concern is. They say you can put on a extreme VB and it will hold the power. Some of the you-tube guys say they don't do nothing to them. I know if my trans break i will put in a 4l80 with manual shift and let her eat($3100 and up for extreme 442. Ha Ha!!!).
Youtube
Key words: turbo land cruiser
YouTube - 950+HP Toyota Landcruiser MoTeC by Kami
Diesel costs as much more then comparable Gaser and more indepth swap
Correct. I dont know if a dmax has the same bolt pattern has a sbc. if it does than the adapters would work. You can run a PPE harness. The harness would eliminate the allison and tranfer case from gm. Also people run 4l80 behind dmax and they live. You would also have run a programmer to reduce the hell out of the dmax until you could upgrade your drive-train.
Stand Alone Hot Rod Engine Wiring Harness - $0.00 : Pacific Performance Engineering, Innovations in Diesel Performance
9k for a kit. Wow.
Youtube
So you claim to be able to do a 1FZ pistons, rods, custom turbo, standalone EFI, and tuning for $5k? If so I expect you could attract a TON of customers. Most of the custom turbo threads report $5k+ for a DIY effort, without internal engine work.
I am going start a new thread.
