Engine wiring ???
Boonsboro, Maryland
Just about got all the wiring done on this thing. Last night I realized I hadnt hooked up the carb solenoid. So I figured I wanted it to be on the same circuit as the power to the coil and ran it over to the other side of the engine and hooked it on the lead side of the ballast resistor. Was checking that the fuel sender was working at the dash. As I looked in the engine compartment, I had a little bit of smoke starting at the resistor area.
Now, I know the solenoid works, it clicks like it should. I THINK I have had the ignition on before with the resistor hooked up, (Just got it) and no solenoid. and all was fine. ignition was not on anymore than a minute or two tops. Enough to walk around the truck. Is that even too long to keep it on without running? Wonder if resistor needed a (jump start) since it hasnt been used in so long.
When I went over to check it out. Nothing was melted, no hot wires. resistor had a hint of the smoke smell to it, but nothing physically noticable. :confused:
Had to go in for the night before I could check it out more. Would it be bad to have the carb circuit hooked up there. Dont see why, it is just feeding 12v to the carb and resistor. ??? Any ideas. Will be getting into it again tonight.
On the good side. It cranks over, all gauges work, wipers work, and heater works. All that is left to do is the lights, and fire this thing up to see how she runs after years of sitting.
Is your Ballast resistor bat + even with ignition off?
The electric choke on my carb, is grounded through the motor, so unless the choke opens to break this circuit the wire will pull power. So I wire my choke bat+ feed wire from a circuit that is ONLY energized from a keyed hot source, but cold/off when ignition is off.......
Anyway this is my WAG.
not hot with the ignition off, everything is switched. I do have the head and block grounded, and I dont think the solenoid would work if it wasnt.
On another side note, I forget where the wire from the coil to the distributor goes. I have it hooked up to the condensor screw (external). Is this correct. or does it go to the screw on the dist. housing.
I dont really want to screw you up, but for what it is worth I burned up a jacobs coil once upon a time. At the time I was using a non-usa vacuum advance distributor that had points. When the vehicle was off the coil or jacobs box was able to ground through the points at the distributor. Being that the Jacobs 'energy' box had a constant hot wire to it- the coil fried.
I take it you are working on a straight six? Any pictures?
Grounding the Engine to frame is correct, I was just pointing out that maybe the electric choke was drawing power somehow when the engine was off. And this was just a 'wild ass guess', electric gremlins can put up a could chase before you catch em.
Sometimes the problem is staring you right in the face, happened to me once when wiring up some friends back up lights- my creativity attempted to ignor the rules of electric flow- popped about 5 fuses before I realized my mistake.
Anyway, pictures of maybe your distributor, new ballast etc. may help speed up the search.
Pics in a couple of days. Been trying to get it all done before I post pics up. The resistor is a used one from SOR, looks to be good condition. I will have to hook it up again tonight without the solenoid hooked to that lead and see if it smokes, if it does then it is definetly the resistor. Resistor does not have an in and out does it? Did not see any markings. I had the resistor zip tied right to the coil. I am wondering if it was somehow grounding out through the coil bracket. It was touching it a bit. Even though the contacts are ceramic spaced???
The truck had a broken resistor in it when I got it, coil is what was in it. I hear there is a resistor type coil, is this correct? This one has no markings to know if it is or not. What is the difference. Does Advanced Auto have them. May just get a new one. ???? I LOVE wiring.
My 9/64 and the 9/70 both have internal resister type coils, and that was how they came from Toyota. Simplifies life a bit. Carb solenoid attaches to the positive terminal of the coil same as the ignition wire (black with a yellow stripe), and opposite the distributor wire, which goes, yes, to the condenser.
Cool, So they actually make a coil where the ballast resistor is not needed? Is that what everyone refers to when they talk about 2 different types of coils. Mine is not I dont think since the resistor was external even when I got the cruiser.
With an external resistor would I still wire the solenoid directly to the coil. Is it just to cut fuel? So it dosent matter if it gets the 6v or what ever after the resistor or the 12v prior.
The resistor I got from SOR has a black with yellow stripe wire going from resistor to coil. Everything else is my own wiring.
I do not have a ballast resistor on mine, both when I put the new harness in, and I did not come across one when stripping the old one out. I'm not even sure what they do, but might it be possible to just leave it off?
And by the way, my rig runs like a charm without it.
I have done enough searching here to know that it is supposed to need one. I only have a Haynes Manual right now, but it is weird that they do not mention it in there anywhere even though they talk about points alot. I will be keeping it in if I can hook it up and it dont smoke. :D
Well we went at it again last night. The smoking resistor was just because it hasnt been used in who knows how long, and SOR probably sprayed it with something. After a minute or two tonught it stopped smoking and was just warm to the touch like the coil was.
Got some spark, got some gas and she actually fired up a bit with some carb cleaner. :D :D :D
May have done better if we didnt fowl the plugs by trying to get it going too long, got it sputtering and trying then we realized that we never put the #1 spark plug back in after checking TDC. hahahahahah. SO its first cough after the grave didnt even need all 6 cyl. Tough little engine.
So gonna clean up the plugs tonight, (put them ALL in). ;) and see what happens, worst case work with the carb a little and do some fine adjusdtments and it just may be good to go.
