I am replacing the main wiring harness in the engine compartment thanks to a red squirell that chewed through the previous harness near where it connects into the ECU. I have found where all the connections go except the one in the photo. Does this go on the stud on the starter? I just want to double check before going that route. If it does not go there then where?
I still have the long harness sections that go up over the transmission. I have a 2" body lift and access is still tight. I wouldn't look forward to running those over the transmission with the body in the stock location.
