Engine Stand Suitable for 1FZ-FE ?
Harbor Freight sells a couple of different stands, from real basic to big brutes. The small ones will hold your engine but they flex alot with a complete engine on them. 4.5ltr is a lot of motor in an in-line configuration. I would get a mid-range stand. However, there is stand out there that you might want to look into. autobodytoolmart.com has some nice ones with a crank on them to rotate the engine. Those are great because these motors are REALLY top heavy and get away from you if you try to roll them over to get to the bottom end with cyl. head attached.
One feature you want is some kind of gusset or steel strap reinforcement on the upright part of the stand. This will help keep the engine from getting bouncy.
