Hi. I have a 1hdft 1995. Recently the engine has started to stall when steering in turned on idle. And if the AC is on it stalls when i even stop it with its gear in "D". I also have a doubt that its gearbox is also heating up more than normal. Will somebody plz guide me what to do.
Regards
There is an idle control system that bumps up the idle speed when the engine has load on it, i.e. the power steering and the AC. Start there with the FSM diagnostics section.
Check your IAC (idle air control) valve. Unless oil burners don't have these, then disregard.
Hi all.
▪︎I checked idle air con valve on my 1hdft but there is none.
▪︎I checked the FSM and there is no mention of it there as well.
▪︎I tried to solve this issue by RPM setting. I raised it till 925 and it was good but when I brought it down to 825 or below it started stalling when the wheels were turned on idle.
▪︎I even took any air out of the nozzles but no effect.
▪︎I have checked air intake and feul lines for any leakage or blockade but there is none.
▪︎Will somebody plz guide me further.
Regards
Hi. This issue was resolved when I got my diesel pump recalibrated. However, another expert told me that one of the causes is old fins of a rotor fitted in the hydraulic pump. Experts can expand this finding further for clarification.
