engine stall at 2000 rpm
DC area
went out mudding with the 80 this week and afterwards sprayed under the hood to wash off the mud packs. Oh. Oh.
On the way home the engine would hit 2000 rpm and then stall out. Anyone have any ideas what I shorted out to cause this????
Thanks.
J
No luck. Took the distributor apart and checked----there is no damage or wetness anywhere. Also there are no engine error codes on the ECM.
It starts ok but when I push the throttle it hits about 2200 rpm then cuts out. Accelerates fine through the 10-2200 range and then, BAMO! it all of suddend stops and drops back. Something is prohibiting the engine from exceeding anything greater than the 2200 range and it doesn't matter whether I'm driving or whether it's in park.
unplug your tps and blast the connector with compressed air may also want try maf connector as well worked for me after i power washed the engine bay:)
