engine smoking
Laramie, WY
Hey,
I had a quick question. I was out today doing some four wheeling and went over a hill, and the cruiser was maybe at a 45ish degree angle, anyhow i was going down it slow and my exhaust started smoking like a mother fawker. After a few minutes the smoke went away and my oil pressure is still running between 15-20 psi at an idle. My question is has anyone had this happen before and could it have damaged the engine. Thanks
Oh, i have a 1970 fj 40 with an f engine pretty much stock cruiser
I suppose your PCV Valve might have sucked some oil into the intake. If you were off camber with the pass side downhill or if you were nose down at 45*, that might have happened. If it is not still smoking.....I really would not worry about it.
JMO
Ed
Yup had it happen before. My buddy bet me that I couldn't climb this steep embankment. Just to show off, I did it in reverse (I also felt much more comfortable facing downhill in case I needed to make any quick maneuvers). Somehow got some oil where it wasn't supposed to be and I fogged the mosquitos out of there for a couple minutes.
I always thought that I got enough oil to the front of the pan that it let the crank splash a bunch up onto the cylinder walls and then it burned off. I don't actually know if that's the case or if that even makes sense...
Either way, no detrimental effects from my experience.
More than likely when you went off camber your carb loaded up. The smoke you're seeing is from partially burnt fuel from a rich mixture.
When carbs are put off camber, (some worse than others)the fuel in your fuel bowl goes out the vent tube and pours into the primary/or secondarys. Too rich of a mixture and you will be sputtering and blowing black smoke.
What engine and carb are you running?
depending on what color smoke it could be a number of things.
white- can be cooling problem and maybe running rich ( if i remember correctly)
black or blue -usually is oil
i donno if im 100% right but pretty sure. had a camaro i thought smoked alot. just turned out the carb needed to be cleaned out. I had fun with that .. ;)
Hey,
I am running a weber 38mm syncronized carb. The smoke was blue and smelled like burning oil. The front end was down at a pretty steep angle for probably 5 secs or so, so i was thinking the oil went to the front of the engine and got into the cylinders and burned out.
Mike
to much oil.. this is what happens to my buddy's 40 when he go's down a steep hill.cough cough.
