Hey guys, I have a 78 BJ40. and when I received the vehicle, the previous owner said he tried to start it by towing it and popping the clutch. I know your not supposed to do this, and so I HAVE NO IDEA IF HE EVEN USED GLOW PLUGS!!!!
and a
Anyways, i think that he may have hydraulicked the engine because he wasn't cranking the engine fast enough, and he had no glow plugs. So this would make it look like the engine was seized. All that fuel in there!!...
I have to pull the injectors and then crank the engine manually first, and then with started after I get some oil moving around.
He said that when he towed it, it was turning over fine, and then the wheels just locked up. And I don't think the engine would just seize.
Let me know what you think.
Thank you.
Brodie
and aAnyways, i think that he may have hydraulicked the engine because he wasn't cranking the engine fast enough, and he had no glow plugs. So this would make it look like the engine was seized. All that fuel in there!!...
Thank you.
Brodie
