Engine shuddering - CEL light on
Wilmington, NC
Need some help on this one guys. I've been working on a cruiser of mine that I actually just bought back from a gentleman I sold it to two years ago. Glad to have her back!
But, I took her for a spin yesterday around the neighborgood (1997 LC) and started to notice that around 900 to 1400 the motor would hesitate or shudder. Thought initially it was the transmission. Only thing slightly abnormal on my guages is that the oil level was a little more than half - which on these trucks I know they typically hover around the 1/4 range.
So last night I poke around on the forum and people say sometimes a high oil level can cause the engine to shudder like I experienced. So, I did an oil change on it this am and filled it with exactly 8 quarts (7.6 is factory but everyone here says 8?). Turn her on, the oil level is now at a bit over 3/4, the shuddering is worse and the CEL light popped on. Ugh! Cut her off and kept her in the garage.
Good news is that I think I can rule out a transmission issue. Other good news is that the oil I removed from the change looks great (not milky, etc.).
Any thoughts guys?
So what’s the code? That’s a good start and check all your vacuum/intake hoses would be another good starting point.
I don't have a code reader. Is there a way to do it without one?
The only thing I've recently done, is replace the two hoses at the top of the motor. Would this cause an issue?
You can get cheap scanner now and days on amazon, just get the Bluetooth or WiFi ones.
It sounds like time for a through check up and tune up. I would check intake hose and all vacuum hoses. Clean intake, wires and plugs.....
You're confusing oil pressure (read from the gauge) with oil level (read from the dipstick).
Go check the level.
So what would cause higher oil pressure??
3/4 on the gauge at start up, then lowering to about 1/2 when warm sounds pretty normal to me. :meh:
You check the level yet?
Oh, and:
Almost any auto parts store will pull the codes for free. If you're too scared to drive your rig there, I'll bet they'd even loan you a scanner.
Dirty pickup. Blocks the suction port. Other than that, nothing. Oil delivery path on this engine is fairly open.
FWIW,
So your combination meter gauge should read nearly nothing at idle and between the lower two marks at operating rpm.
And to echo the comments above, the gauge indicates pressure, the dipstick indicates quantity. There is an oil level idiot light, but by the time that comes on, you're low. Mine has never come on and my oil pan leaks so much I can't keep more than 6.5 qts in it. (It's on my list)
Just as a follow-up - new plugs and wires and she's now strong as ever.
I new it. I have the same problem when it sits at idle, but works well at higher idles. I am about to do the same. I figured it was plugs since the shudder has a rythm
